It is currently Thu 21. Nov 2024 20:43:52
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue 28. Mar 2017 18:35:54
Hello
It is also possible to loop through the Jeti EX-Bus signal and forward it to a CB200?
The servos attached to a CB200 as the Cortex Pro is the case?
Would be useful for models with multiple servos ....
As in the picture.
PostPosted: Tue 28. Mar 2017 22:24:11
it is possible with all our units even before Cortex supported it.
Regarding servos, you can do this, but the unit can't control them (only your transmitter).
I believe that this is same with Cortex, since there is probably no way, how it can be realized with current protocol.
PostPosted: Wed 29. Mar 2017 6:02:11
Ok, thanks.
PostPosted: Wed 29. Mar 2017 8:02:20
Good morning.
This topic makes me curious again.
I had the same wish a couple month ago:
http://www.spirit-system.com/phpBB3/viewtopic.php?f=29&t=1428
And now you reply on a interesting way.
You say we can put the SPIRIT in between but it will not modify the EX-BUS-Signals?
So the GYRO will not work as GYRO and just passt the Signals through?
Did I understand that right?
Ingbert
PostPosted: Wed 29. Mar 2017 13:05:55
7kyf0x: regarding your question there is nothing different.
But stipsi asked if you can connect Spirit to CB200 through EX Bus - and this is possible.
But you can't pass signal from the unit to CB200 and then to the servos. And even if it will be possible, it will be rather delayed (not good for model control).
PostPosted: Wed 29. Mar 2017 17:06:12
Hi
Only to the correct position, with the Cortex Pro is the Gyro but usable in connection with EX bus and CB200.So it is in the instructions ...
Gesendet von meinem GT-I9195 mit Tapatalk
PostPosted: Wed 29. Mar 2017 21:47:03
Maybe it depends on interpretation. But as I have written previously, with Spirit you can also use CB200 + EX Bus.
If it will be technically possible to move servos through EX Bus, we can implement it - this should be easy.
We will ask Jeti if they plan to release the feature.
PostPosted: Thu 30. Mar 2017 17:39:47
Here is an excerpt from the description ....
PostPosted: Thu 30. Mar 2017 17:56:15
Hallo Stipsi!"
Habe deinen Post auf Jeti Forum gelesen!
Wegen diesem Thema Spirit Aero und Jeti Integration bin ich hochkannt aus dem Forum geflogen. Ich wurde nur angelegen und habe aber nicht nachgelassen, das Ergebnis war der Rausschmiss!
Ich kann dir nur eines sagen ,ich und meine Kollegen haben das Spirit in den Helis drinnen und auch jetzt in der Fläche und das Aero funktioniert sehr gut. Ich habe mir einen Wifi Link gekauft ,kostet ein paar Euro und stelle den Flieger mit der Aero App ein. Funktioniert perfekt! Und auch sehr einfach. Ich für meinen Teil brauche keinen Assist mehr, wer weiß wann der kommt?
Liebe Grüße Gernot
Greetings from Gernot
PostPosted: Thu 30. Mar 2017 18:16:27
Hi Gernot
Habe alles mitbekommen! Hast dich aber auch zweimal Registriert, darum "anscheinend" dein Rausschmiss.[WINKING FACE]
Spirit Aero wäre auch für mich erste Wahl wenn man ihn so wie oben zwischen Empfängern und CB200 einbinden könnte! Da ich auch grössere Modelle mit mehreren Servos betreibe.
Jeti Integration wäre sehr nett aber wie du sagst auch für mich zweitrangig. Mich stört nur das warum!!
LG
Christian
Users browsing this forum: No registered users and 17 guests
