It is currently Fri 22. Nov 2024 7:18:15
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Post subject: Re: Micro Spirit?
PostPosted: Wed 15. Mar 2017 1:14:28
Is this new micro will provide any telemetry from Castle ESC :?: I'm thinking the 180 CFX ESC have the Link Live option.
I would like to use voltage instead of the timer.
PostPosted: Wed 15. Mar 2017 7:12:34
mrnets wrote:
Is this new micro will provide any telemetry from Castle ESC?
ZeXx86 wrote:
It will be supported by all Spirit units.
PostPosted: Mon 10. Apr 2017 8:59:46
I've just seen the µSpirit announcement. I think in this size it would be better, not to use an aluminium case to save weight, which is very important in the (sub)micro heli range.
best regards Wolfgang
regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
PostPosted: Mon 10. Apr 2017 9:19:18
the weight is just 7 grams. We believe it is much better to have rigid unit that will sustain any crash. With plastic it could be 5-6 grams, so 1 gram for such feature is much better we think :)
You can save this 1 gram by using a light rotor blades, cables, canopy and even connectors.
With plastic it is possible you might change case or even unit due to possible damage each crash = bigger cost and more troubles.
Our goal is to provide high quality units that will work for long time.
You can take a look for example on microBrain 2 which weights 6,4g even that it is made by cheap plastic. So difference is very small, but crash and vibration resistance reduced and actually the unit is more expensive :)
PostPosted: Tue 11. Apr 2017 0:42:23
Cant from descripting does it have a connecting for Spetrum Satellite ?
PostPosted: Tue 11. Apr 2017 8:47:44
μSpirit supports Spektrum DSM2/DSMX and contains one native Spektrum connector.
Basic parameters can be seen here: http://store.spirit-system.com/en/flybarless-units/30-uspirit.html
Users browsing this forum: No registered users and 24 guests
