It is currently Sun 24. Nov 2024 2:05:17
PostPosted: Sun 19. Feb 2017 17:03:16
I got a Problem with the HoTT integration. I updated 2 of my Spirit units an connected them with the wire shown in the wiki and can see an GAM in the telemetry display an select it. So far so good but it isn´t possible to adjust anything else than the receiver in the telemetry menu.
What are I´m doing wrong?
My setup:
Tx ist MC-20
Rx is GR-18 or GR-12 3xG
I have updated the receivers and the transmitter too, but nothings happened .
Greets
PostPosted: Sun 19. Feb 2017 17:10:44
in the receiver menu you have to switch page to the last one.
Even that you will select GAM, the Spirit integration is always at the last page of the receiver menu.
If unit is present, then it will show you that there is additional page available and this is the Spirit.
So it is normal you can see only Receiver at the beginning, but when you will move through the pages, you should end in the Spirit menu.
If you can already see GAM in the Telemetry, then it will work.
PostPosted: Sun 19. Feb 2017 17:33:40
ok, I´m trying it in this moment. The first page in the telemetry menu is rx data, next is rx servo, rx fail save, rx free mixer, rx curve, rx servo test and that´s all. There comes nothing more..
Here some pictures. Sorry on my Mac they where on the right side :roll:
PostPosted: Sun 19. Feb 2017 17:52:06
Please try to press < > and change the current sensor to General. I dont know MC-20, but there should be menu directly in the Sensor & Data View to change the Telemetry sensor from RX to GAM.
Alternatively you can do it in the Telemetry menu.
If it is not switched to the General, then the transmitter will not see the Spirit page.
What I recommend to do is:
1. turn off everything
2. turn on the transmitter
3. turn on the unit and receiver.
4. after the initialization of the unit, change Telemetry sensor to General
5. go to the Sensor & Data View
6. go to the last page and it should work.
PostPosted: Sun 19. Feb 2017 18:15:48
Mc 20 should be similar to mx20. First go to sensors & data view and switch to general air module using up or down arrow on left control. Then go to last page using right arrow
PostPosted: Mon 20. Feb 2017 10:13:48
ok, i tryed the steps you wrote but i can´t select or deselect any sensor in the menu "telemetry/sensor select". It shows me the selected RX and the GAM. It´s curious because the Graupner Manual says that you can do so... :?: See attached picture
In the Sensor/Data View menu i also can´t switch from RX to GAM... In the telemetry display (the upper one on the TX) i can select RX or GAM to view the data of the choosen sensor.
I tryed to rebind the RX with and without any sensors but it didn´t change anything. :cry: I think i´m doing something wrong because the TX knows about the Spirit as the GAM.
PostPosted: Mon 20. Feb 2017 10:54:15
you have to always go to the Setting & Data View and then by up/down arrow select General. Only when correct sensor is selected, you can see that new page (Spirit) will be available.
By default it will return to RX, so you have to always change the sensor.
In Sensors menu you can see only available sensors, but can't switch it.
PostPosted: Mon 20. Feb 2017 12:58:34
ok, shame on me! This was my fault an the reason why it din´t work :oops:
Very embarrassing :lol:
Thanks a lot guys, now everything is working fine.
Greets
PostPosted: Mon 27. Feb 2017 9:34:11
great! You are welcome.
Users browsing this forum: No registered users and 34 guests
