It is currently Sun 24. Nov 2024 1:03:13
PostPosted: Thu 12. Jan 2017 0:33:30
Hello everybody.
I have just received my wifi link, but I'm not able to connect Spirit settings with my spirit pro using wifi link under android.
I have connected my unit via PC win10, using Firefox browser and ip adress 192.168.4.1, and checked wifi link and spirit pro firmwares. Both are 2.2.0 version.
Under android 6.0 I can connect to wifi link network under system settings, but I can't acces the unit through my web browser ( chromme) using ip 192.168.4.1 and neither I can connect Spirit settings app
Any ideas?
PostPosted: Thu 12. Jan 2017 8:13:04
is the WiFi module still powered in the same way as in the case where you were able to connect by Firefox?
If you can connect there with Firefox then it is possible to connect there also with PC software as you know from USB interface (you can enter the IP there with CTRL+W).
But definitively if you are connected to the Wifi Link network directly, you should be always able to connect to http://192.168.4.1 even that the Spirit unit is not connected.
Sometimes Phones are switching between networks on its own, maybe this happened.
PostPosted: Thu 12. Jan 2017 8:42:07
Yes. Spirit is powered in the same way as using Windows.
The problem is that I need to connect with my Android phone so I can make adjust in the unit in the field.
As I can see, iPhone is not changing between networks. It is always connected to wifi link link. And I dissabled my home network to be sure there was no interference with it, but I get the same result
Enviado desde mi MI MAX mediante Tapatalk
PostPosted: Thu 12. Jan 2017 8:58:04
Problem solved just now.
Phone was notifying in the notification bar there was no internet connection through wifi link network and network was dissabled till I answered «use this network anyway»
Thanks for everything
PostPosted: Thu 12. Jan 2017 9:01:12
Perfect, you are welcome!
Thank you for the info.
Users browsing this forum: No registered users and 75 guests
