It is currently Sat 23. Nov 2024 23:15:49
PostPosted: Mon 09. Jan 2017 3:20:31
I'm getting the following error message when I run either script on my Taranis. Any ideas?
Thank you
PostPosted: Mon 09. Jan 2017 8:57:17
you will need to perform update of the Taranis firmware to version 2.2. Earlier version unfortunately does not support the integration.
You can download it here:
http://www.open-tx.org/2016/12/03/opentx-2.2.0RC8
Because it is still in development, you have to enable Nightly builds in the Companion preferences.
Also it is needed to update SD Card content.
If you will be unable to start it with a new firmware, you will have to load it via builtin bootloader.
I recommend to backup everything first.
Or you can just wait until they will release it as a final version. Unfortunately it takes little bit longer than expected :(
But 2.2.0-RC8 is nearly finished.
PostPosted: Mon 09. Jan 2017 17:38:47
My mistake. I should have known that. Thanks for the quick response.
Users browsing this forum: No registered users and 16 guests
