It is currently Sun 24. Nov 2024 7:51:32
Ktm250
Posted: Sun 18. Dec 2016 22:47:01 |
I am trying to get my Horus to spirit integration working. What I am seeing is that when I run the script is that most of the time it seems to lockup when it is trying to pull the info from the spirit. Once in a while it will work but even then it locks up. Not sure why it is doing this. Any thoughts? Thanks
Posted: Sun 18. Dec 2016 23:12:59 |
Hello
Maybe you are in the Bank 1/2. Try to switch to Bank 0 - there all parameters are visible. When you are in the Bank 1 or 2 some parameters are hidden.
Ktm250
Posted: Mon 19. Dec 2016 18:16:43 |
I am not using or have selected banks. Maybe I didn’t explain it correctly. What happens when I run the script is the first page pops up and at the top of the page the progress bar appears. Sometimes the bar never moves or it moves part of the way and then locks up. So I either get some of the values or none. When it does this I unplug the spirit which also is powering the receiver. I then plug it back in and it may work or not. It fails more times than it works. Hopefully I have given you a better problem statement.
Posted: Mon 19. Dec 2016 23:18:02 |
That is quite weird.
Can you tell me what receiver you are using and which version of the OpenTX you are running? Do you use any other telemetry sensors?
Ktm250
Posted: Tue 20. Dec 2016 0:47:01 |
I am using a X4R-SB receiver along with a MLVSS voltage sensor. The opentx version is 2.2.0 RC8. Thanks
Posted: Tue 20. Dec 2016 9:19:09 |
Thank you!
Could you by a chance try it without the additional sensor? If it will help, we will know where the problem is and very likely also to fix it by a small update.
Ktm250
Posted: Tue 20. Dec 2016 13:36:09 |
I will try that tonight and get back to you. Thanks for the help
Ktm250
Posted: Tue 20. Dec 2016 22:10:19 |
Ok I unhooked the MLVSS and it no longer locks up. But it is very very very slow bring the values in. Not sure if that is normal or not. If so then it makes it very unusable. Thanks
Posted: Tue 20. Dec 2016 22:16:25 |
Great. I suspect that there is something wrong with the line connection. Isn't it too long? It should load all values usually in 2 seconds. Do you have enabled a scanning for telemetry sensors (automatic detection)?
What OpenTX firmware version is loaded in your Horus?
Ktm250
Posted: Tue 20. Dec 2016 22:46:17 |
I'm using opentx version is 2.2.0 RC8. I looked under telemetry and you have to tell it to discover new sensors. I don't see any auto mode.
Users browsing this forum: No registered users and 25 guests |
