It is currently Fri 22. Nov 2024 7:20:29
PostPosted: Tue 06. Dec 2016 9:35:12
Hi.
Is there a way to see the pwm-output from the SPIRT for the ESC?
I just want to know if I am useing the right gear ratio and if I maybe can increase headspeed.
Or for other diagnostics.
Thank you
Ingbert
PostPosted: Tue 06. Dec 2016 9:44:30
unfortunately this is not possible.
Spirit can't get throttle signal, since throttle channel is not passed to the unit at all.
So it can't be either viewed nor controlled by the unit.
In PWM all is directly passed through receiver, so you can check it directly in your transmitter or just re-calibrate the ESC.
PostPosted: Tue 06. Dec 2016 10:06:39
Hi.
I think we have a misunderstanding.
If I use the SPIRIT-Governor and this is what I do on my Voodoo.
The Governor controls my YGE-ESC.
And also in this case I cant see the output for ESC-Controlling on the SPIRIT?
Ingbert
PostPosted: Tue 06. Dec 2016 10:33:12
In this case you can see it (in case of heli directly in the Diagnostic tab).
In Aero it is displayed just in the Channels window.
PostPosted: Tue 06. Dec 2016 11:30:53
Thank you.
Is it possible to get this value as a sensor-output like for the vibes and rpm?
