It is currently Sat 21. Sep 2024 6:35:16
[ 8 posts ] |
sacha
Posted: Fri 15. Apr 2016 15:04:50 |
Hello
I'm a big fan of the Spirit System and i have converted already several birds.
Now i run into a problem:
The Setup is the following, jeti transmitter:
Jeti RSAT2 (EX-BUS)-> Jeti Centralbox200 -> (EX-BUS) -> Spirit Pro (2.01)
When i connect the Spirit to EXT1 (EX-BUS) connector on the centralbox i see both devices (Centralbox200 and Spirit) in the transmitters device-explorer. But i'm not able to enter/select the Spirit or the Centralbox. I got the message, that the device is not online.
When i connect the Spirit to EXT2 or EXT3 (EX-BUS) connector on the centralbox i can enter/select the Spirit pro, but not the Centralbox. I see both devices, but i'm only able to select and enter to the Spirit.
When i unplug the Spirit pro, i can always enter and configure the Centralbox.
Sacha
sacha
Posted: Fri 22. Apr 2016 7:00:25 |
Dear Spirit Team. Any suggestions / opinions ?
Sacha
Posted: Fri 22. Apr 2016 7:09:18 |
unfortunately we can't respond to this question appropriately. You should ask Jeti support to clarify this.
In any case I will try to get this information from Jeti too.
I believe that centralbox is missing required data for Spirit (it needs e.g. Spirit BIN file).
7kyf0x
Posted: Fri 22. Apr 2016 8:46:05 |
Joined: Wed 16. Dec 2015 22:31:27 Posts: 44 Location: GERMANY
May I ask you a question Sacha? I am a little curious.
Where do you use this combination of CB200 and Spirit? On a Plane? Sorry for being OT, but I am really looking forward to have a Spirit in my Krill Extra 330SC.
Thanks Ingbert
sacha
Posted: Fri 22. Apr 2016 13:14:32 |
@ZeXx86
Thanks for your answer. I don't think that the CentralBox200 needs a .bin file. The CB200 together with 2 RSATs is basicaly a redandent receiver with 3 ext-bus outputs.
Sacha
sacha
Posted: Fri 22. Apr 2016 13:16:12 |
@7kyf0x
I will use it on a Heli. A Velos880.
Sacha
phoinix
Posted: Wed 16. Nov 2016 20:52:42 |
I'm having problems with Spirit PRO and CB200 connected via EX bus. CB keeps falling offline and of course to failsafe. I have two seperate systems with same result, hardware error excluded. Do you have the same problem?
Posted: Wed 16. Nov 2016 22:00:09 |
We are investigating the issue with Jeti. It looks like there is some issue with CB200 so that it can't handle EX Bus connection well.
[ 8 posts ] |
Users browsing this forum: No registered users and 39 guests |
