It is currently Sun 24. Nov 2024 1:50:42
PostPosted: Tue 27. Sep 2016 8:51:12
hi,
first, i didn´t change anything, just did the update
when gov is enabled, the motor doesn´t start.
when gov is disabled, the motor runs immediately after switching the switch.
ESC is calibrated, values in spirit are 0 and 100%
log is clean
any idea?
ESC is a YGE160HVK
thanks, Flo
PostPosted: Tue 27. Sep 2016 9:49:57
what will happen if you will wait little bit longer?
Was the ESC recalibrated after the update or something else?
If completely nothing was changed (except firmware), it should work in the same way as the old firmware.
PostPosted: Tue 27. Sep 2016 10:09:41
i didn´t change anything!
waited 1 minute, nothing.
one time, the motor started with gov activated, when i switched to the next bank.
throttle value from 64% to 75%
PostPosted: Tue 27. Sep 2016 10:09:57
but i tried it very often
PostPosted: Tue 27. Sep 2016 10:12:49
Good. Can you please share your settings? At least for Bank 0.
PostPosted: Tue 27. Sep 2016 10:20:24
here it is
B0D700.4ds [255 Bytes]
Downloaded 50 times
PostPosted: Tue 27. Sep 2016 12:49:19
I had the same problem with one of my helis after updating to 2.1.
I solved the issue by increasing Spoolup Rampup from 50 to 60µs
I hope that solves your issue too.
brgds
Guido
PostPosted: Tue 27. Sep 2016 14:18:09
it works.
i recalibrated the ESC, same problem.
increasing spoolup rampup to 80 was succesfull!
PostPosted: Tue 27. Sep 2016 20:30:39
I had a similar issue on 2.1 where the governor was not engaging at all until I set the spoolup rate to fast
PostPosted: Wed 28. Sep 2016 9:23:15
Thank you for the info.
I am glad it works, although it is little bit strange as the starting procedure is very same with previous firmware.
Increased spoolup works similarly as when you increase Throttle Range - Min.
Users browsing this forum: No registered users and 58 guests
