It is currently Sat 23. Nov 2024 21:52:00
PostPosted: Fri 16. Sep 2016 2:51:31
Is there a way to flash the unit's firmware through the WiFi interface, or does it have to be done through the USB interface? If so, how?
PostPosted: Fri 16. Sep 2016 7:06:41
yes, you can flash the firmware without any problem.
Just start the PC software and do the update normally as you are used to with USB interface.
You can find how to connect the software in the Wifi-Link guide.
PostPosted: Fri 16. Sep 2016 12:34:09
Okay, I'll try that tonight. I was connected via WiFi, and I was trying to update the unit using the Web interface. You said "PC software," so I'm assuming that means the Spirit Settings application I have on my PC.
Sent from my phone using Tapatalk
PostPosted: Fri 16. Sep 2016 12:39:15
Yes, you are right.
Users browsing this forum: Bing [Bot] and 35 guests
