It is currently Sat 23. Nov 2024 22:08:24
PostPosted: Sat 03. Sep 2016 10:46:56
Hey everybody,
I have many spirit red and spirit pros. one of my spirit pros stopped working without any changes. When i power it up, i instantly get a solid red light with nothing else. The spirit light stays solid but the servos will not power up, and the spirit appears to not initialize. The computer cannot see it. it behaves like it's dead, except for the fact that i get a solid red light...HELP! Any ideas?
PostPosted: Sun 04. Sep 2016 10:02:52
The behavior you are describing is not really OK.
You can try to reflash the firmware through recovery process.
You can use instructions from here:
http://spirit-system.com/phpBB3/viewtopic.php?f=20&t=1397
Do you remember what you have did before the issue happened (whatever it was)?
PostPosted: Sun 04. Sep 2016 10:29:24
I was trying to update the flybarless but I never got to get it to be recognized my computer so here I am!
PostPosted: Sun 04. Sep 2016 11:02:53
This is not a problem with Recovery process.
It is not recognized, but recovery process can connect to it when you will proceed according the instructions.
It is important to not start the power until you will press the Flash and OK buttons.
PostPosted: Sun 04. Sep 2016 12:31:51
It doesn't seem to work...
PostPosted: Sun 04. Sep 2016 23:06:25
Ok my friend, I've tried several times to flash it with no luck. Any other ideas?
PostPosted: Mon 05. Sep 2016 7:26:50
You can try to disconnect everything except power.
Unfortunately without inspection I can't tell you more.
If nothing will help, it will be better to send to us (or Esprit). If you are in hurry we can do everything in a few days (including import/export) shipping.
Please check your private message.
PostPosted: Mon 05. Sep 2016 16:56:16
Hey Tomas, I tried responding to the IM and it's stuck in the outbox. I asked if you could send me instructions for sending it to esprit model. I think it would be cheaper and faster to send it to them....
PostPosted: Tue 06. Sep 2016 8:03:33
I have responded to your email.
Users browsing this forum: No registered users and 29 guests
