It is currently Sat 23. Nov 2024 22:47:29
PostPosted: Wed 31. Aug 2016 7:24:19
When trying to update my software for some reason....I guess the Spirit program is not recognizing it or something??
Just to not confuse I downloaded the upgrade to my system, but when I go to selct it to update the program there is nothing in there in the Spirit folder.
But i can without using the updater see the files once I am out of the Spirit program....
PostPosted: Wed 31. Aug 2016 7:28:15
can you explain how did you performed the update?
You can normally start the software (it should recognize the unit), select the file in the Update tab and press the Flash button.
Then wait few seconds and you are done.
Firmware has always extension "4DF". Are you sure you have downloaded the firmware?
PostPosted: Wed 31. Aug 2016 7:49:13
Are you talking about this? the firmwire? If so when I download it I get this other window about an app and there is no Spirit program listed....
PostPosted: Wed 31. Aug 2016 7:55:48
Is this the file I am looking for??
PostPosted: Wed 31. Aug 2016 8:03:05
ok I found it, thank you Tomas!
PostPosted: Wed 31. Aug 2016 8:09:29
Yes, you are right. You can also untick option "Always use this app to open...". This can cause some troubles.
Users browsing this forum: No registered users and 56 guests
