It is currently Sat 23. Nov 2024 21:47:52
PostPosted: Thu 18. Aug 2016 10:02:32
I have a Hobbywing 50aV3 and a DX6 tx. Both display throttle in sync from 0 to 100. However the 50aV3 won't enter programming mode unless I up the tx endpoint to about 118. Any suggestions on how to bring that down so the ESC enters setup at 100 so I can accurately set the throttle range?
PostPosted: Thu 18. Aug 2016 10:22:41
I assume you are using SATs and ESC pluged into Spirit. Have you tried to increase max Throttle range in Spirit? This will raise upper limit towards ESC.
TAB General => Gov/Throttle (Settings) => Throttle Range => Max 1950us
PostPosted: Thu 18. Aug 2016 10:33:57
Yes, one satellite. No I will do that. Do I still need to calibrate the ESC afted since the Spirit will be matching after I increase the max throttle range? Sorry, still learning.
PostPosted: Thu 18. Aug 2016 10:45:58
Yeap just increase the range a bit to get it to recognise max throttle then calibrate. Don't change the range after that though!
PostPosted: Fri 19. Aug 2016 8:14:44
Thank you. So I'm trying to get from the 6 beeps that indicates 6 cells and armed, to two beeps indicating programming mode and stick at 100%. Max throttle was at 1900µs, and increased all the way to 2140 before the 6 beeps changed to constant beeping which just indicates the stick is not in the bottom position when powered on. 2130µs activates the 6 beeps. Not sure what to do next. I know if I up my TX throttle end point I can trigger programming mode. Not sure what to do next.
PostPosted: Fri 19. Aug 2016 9:56:11
Ok a couple of things for you to try:
1. Reset the ESC to factory settings
2. Set the gov end points to the default values
3. Calibrate your transmitter to output 0-100 in the diagnostics page on Spirit
4. Then retry calibration. Governor should be switched off (tick box unticked).
It should work straight away :) the range mentioned above is way over the default and way over the values you need in your TX to set end points so there is something miss calibrated.
PostPosted: Fri 19. Aug 2016 19:01:54
Follow sugested steps. If you wanna monitor whats send to ESC, use a Y Cable and plug a Servo in parallel, servo arm movment represents signal to ESC.
PostPosted: Fri 19. Aug 2016 20:10:32
The governor was on. Now I know. Thank you, she's flying better than ever!
PostPosted: Fri 19. Aug 2016 20:19:44
Yeah you need to disable it, calibrate then re-enable it.
Users browsing this forum: Bing [Bot] and 38 guests
