It is currently Sun 24. Nov 2024 7:19:17
[ 4 posts ] |
LowAndSlow
Posted: Wed 20. Jul 2016 9:12:29 |
Joined: Mon 16. May 2016 16:34:05 Posts: 5 Location: Austria, close to Vienna
I just can't get it working:
Spirit v 2.0.1 with JETI REX6, EX Bus connection, JETI DS-16, Spirit Integration is working Heli is a standard TREX 500 Pro DFC, 500MX motor, ESC=HW Platinum 100A v3 Govenor enabled in Spirit setup, ESC throttle cable connected to AUX, orange RPM signal cable from ESC connected to middle PIN of ELE/PIT/AIL When I spin up the motor, requested RPM and actual RPM display in the Settings App stay unchanged at 0 It looks like no RPM signal is recognized in the Spirit box, saving the config and rebooting the unit did not help either, I checked the RPM signal from the ESC with a oscilloscope - square wave signal looks pretty good to me.
What else can be wrong ?
Thanks Gerhard
Posted: Wed 20. Jul 2016 9:58:57 |
you have to set throttle curve to 50% and higher, then you should see it. Only then governor is activated, thus you can see Requested RPM and Current RPM. Requested RPM is not using RPM sensor at all, it is calculated from TC. Also I recommend to update to the latest firmware 2.0.2 (with Jeti file too), because you are using REX receiver.
LowAndSlow
Posted: Wed 20. Jul 2016 20:53:18 |
Hi !
Upgraded to 2.0.2, setting a constant throttle curve >50% and now it works. I obviously used a too low throttle for testing.
Great support, keep up that "Spirit"
Thanks again Gerhard
Posted: Fri 22. Jul 2016 7:22:29 |
Great!
Thank you very much!
[ 4 posts ] |
Users browsing this forum: Graham00 and 13 guests |
