It is currently Sat 23. Nov 2024 19:22:34
 Post subject: It's like Expo on Pitch
PostPosted: Sat 09. Jul 2016 20:03:22
Hi there,
Made some flights now. Played with style and cyclic feed.
I noticed, that Pitch feels like with Expo on it. Had 12,5 degree cp and need a Lot more way on the stick than before with a brain.
Is there a setting that could explain this behaviour?
Thanks, Flo
PostPosted: Sat 09. Jul 2016 20:18:29
Spirit unit transmit pitch signal directly without any modification.
This mean that there can't be any influance by the unit.
What is possible that your previous configuration with Brain affected collective pitch channel in some way.
Or if your helicopter is after crash, some head bearings are faulty.
You can use Pitch Pump Booster in the unit to make pitch control more agressive.
PostPosted: Sun 10. Jul 2016 7:26:39
hi,
affects pitch boost only fast stick movements or is that a kind of expo for pitch?
PostPosted: Sun 10. Jul 2016 20:50:48
Yes, but it can feel similarly as expo on the pitch channel.
All in all, the unit does not use Expo in any channel, unlike other FBLs.
PostPosted: Mon 11. Jul 2016 8:55:59
ok, i´ll try.
Users browsing this forum: No registered users and 13 guests
