It is currently Sat 21. Sep 2024 6:56:34
[ 7 posts ] |
phil.d.basket
Posted: Sun 10. Jul 2016 19:20:20 |
I use a Spektrum DX6 to activate rescue via bank switching: Bank 0 for normal flight w. positive rudder gain, Bank 2 for rescue w. negative rudder gain.
At the field, w. Throttle Cut active, I used a smartphone to change a Bank 2 parameter, saved it, and disconnected the WiFi module w/o powering down. I prepared for takeoff, switched off TC and an ESC-governed soft start began, followed by a rapid rpm increase and an accelerated, uncontrolled, climb out.
It appears that Bank 2/Rescue was active even though the gear channel value was negative.
jgiannakas
Posted: Sun 10. Jul 2016 19:50:03 |
If the gear channel value is negative this activates rescue. Not sure what was unexpected as this is by design?
phil.d.basket
Posted: Sun 10. Jul 2016 19:57:17 |
The Gear (#5) channel is used to send the value of a bank selection parameter: -100% for Bank 0, 0% for Bank 1 and 100% for Bank 2.
Posted: Sun 10. Jul 2016 20:25:39 |
If you have not clicked to Disconnect button in the App, it will still behave as when you are doing configuration. Thus selected bank in the App will be active all the time.
If you only disconnect from the wifi, it is not enough unfortunately.
phil.d.basket
Posted: Mon 11. Jul 2016 3:00:33 |
I'm using WiFi-Link 2.0.2 System Settings & haven't been able to locate the Disconnect option. There is a Close the Spirit Settings button on the Connection page - would that work?
Posted: Mon 11. Jul 2016 7:21:58 |
Yes, this is the right button - "Close the Spirit Settings".
Until you will press it, it will be still active (same as when you are flying with running PC software).
Adrian
Posted: Wed 13. Jul 2016 8:34:57 |
Joined: Thu 08. Oct 2015 14:43:12 Posts: 204 Location: Switzerland
I would suggest use of LED for Indication on FBL, as this happened to me as well with BT Module using banks to test different settings.
permanent ON = Operation Bank 0 with 1 short OFF seq. = Operation Bank 1 with 2 short OFF seq. = Operation Bank 2 fast flashing = Konfig Mode (PC / Wifi / BT )
_________________ Oxy4max SpiritPro + HW // SOXOS 550, SpiritPro, HW120A V4, 920KV // SOXOS 600, SpiritPro, HW160A, Pyro650 // SOXOS Strike7, SpiritPro, HW160A, Pyro750 // Skywing Spirit Aero // FrSky Horus X10S + Taranis X7 /
[ 7 posts ] |
