It is currently Sat 23. Nov 2024 19:13:36
 Post subject: Governor With Jeti Mezon
PostPosted: Sun 19. Jun 2016 6:32:33
Hey everybody,
I hope somebody may know the answer to this. I have a Jeti mezon 130 in my 3 bladed Goblin 570 and i use the spirit pro governor. i have FW version 2.0.2 (because I'm using a rex7 receiver). when i spool it up, it will get to roughly 1600-1800 then slow down roughly 200 rpm. it will then start to climb up to normal RPM. This process causes my spool up time to be roughly 35-45 seconds...;any idea what may be going on?
Thank you!
James
PostPosted: Sun 19. Jun 2016 17:55:05
Search for the mezon external gov guide by hacker and use those settings, but you will never get good performance. Mezon has a lot of delay so unusable for external gov
PostPosted: Mon 20. Jun 2016 7:11:49
Where can i find this guide? I've searched everywhere...
PostPosted: Mon 20. Jun 2016 22:00:35
Here is it.
Sacha
Master MEZON VBar Gov.mode D-E.pdf [1.44 MiB]
Downloaded 127 times
Users browsing this forum: Bing [Bot] and 9 guests
