It is currently Sat 23. Nov 2024 20:12:39
PostPosted: Sun 19. Jun 2016 18:11:28
When I was practising auto rotations I noticed sometimes the heli would tilt during spoolup again(always to the left so I give right cyclic) . I really had to correct on the ground to make it not tilt over.
First spoolup is always fine
It seems rather hard (but nothing weird) landings can mess up the Spirit?
PostPosted: Sun 19. Jun 2016 22:29:21
If the helicopter is moving, the unit will still try to correct and stabilize it to the desired position (that you want to achieve by stick movement).
If helicopter is without a motion, it will immediately reset it to the center - then it is good to start again.
By the way, I would like to know, why you are asking so many questions here, when there is nobody else that can answer it really?
You can ask me directly.
Your questions are really very specific..
PostPosted: Sun 19. Jun 2016 22:36:31
Hi, I for one am interested in the behaviour during autorotation so please continue with this here.
Assuming that the governor will soon be fixed, I would like to move a Spirit to one of my nitros and will be practising autos too.
PostPosted: Mon 20. Jun 2016 9:58:56
It doesn't reset instantly. The tilt overs are after at least 4 seconds on the ground. Its not happening always but had it a view times. Had to give right cyclic to stop it.
PostPosted: Sun 26. Jun 2016 19:30:04
I guess I have to make a video of the problem (again) to be believed...?
PostPosted: Sun 26. Jun 2016 20:04:22
It is not necessary. If you feel that it shouldn't really do this, I guess that something is wrong.
The unit will hold the last command until it is without movement - this is correct behavior.
So when you do the autorotation and right before landing you will apply stick to some side, it will still try to reach this position.
But it shouldn't do anything additional (what you have not did with the sticks). If this is what you are observing, then we have to find the problem.
Users browsing this forum: 10x, Bing [Bot] and 46 guests
