It is currently Sun 24. Nov 2024 7:51:49
PostPosted: Tue 14. Jun 2016 7:49:21
Hi All,
I was wondering if any out there is using the Spirit with the Oxy 3 Cube which has the 3 Bladed head system.
I am just about to set up mine and before doing so was hoping someone out there has already done so and could maybe help with the general set up, before tweaking :roll:
Hope someone has knowledge about this and maybe is the same as the normal set up but just to be sure :D
Thanks to the team and support and for the great FBL system.
Nik
PostPosted: Tue 14. Jun 2016 7:58:58
yes, there are some pilots with this setup. In the Support settings there were some questions, but overall there is nothing special in the settings.
It is very similar to 2 bladed setup. Gyro Gains can be decreased little bit.
PostPosted: Tue 14. Jun 2016 10:58:05
Thanks will go ahead with the set up.
Will try standard and if need play a bit with the gains :mrgreen:
Users browsing this forum: Bing [Bot] and 13 guests
