It is currently Sat 23. Nov 2024 19:32:59
 Post subject: 3 blades rotor heads
PostPosted: Tue 31. May 2016 21:31:55
Can you tell me if the Spirit controller supports multi-blade rotor head? If yes, how do I change the swashplate timing.
thanks
 Post subject: Re: 3 blades rotor heads
PostPosted: Tue 31. May 2016 21:49:51
Yes it does.
In the pc software, advanced tab, expert settings, and there is the "cyclic phase" what you are looking for.
PostPosted: Tue 31. May 2016 22:53:42
thanks, I am new to the multi-blade rotor system, can you tell me what is the proper phase to set a three blade rotor?
thanks
PostPosted: Tue 31. May 2016 23:28:02
Depends on the rotor head. Mostly 3 blade systems uses the sam 90 degree as the 2 blades systems, so you dont have to do anything with this setting. What head exactly are you talking about?
PostPosted: Wed 01. Jun 2016 0:47:08
Gaui X7 three blades.. thanks
PostPosted: Fri 03. Jun 2016 18:25:43
You Need to adjust it until the blade which is over the boom does not move when using cyclic forward- this value may vary as mentioned depending on head geometry
BR,
Markus
PostPosted: Fri 03. Jun 2016 19:44:22
I think gaui x7 3 blade aldo uses 90 phasing so you dont need to do any specific with it.
PostPosted: Sat 04. Jun 2016 1:28:07
Could well be the case....but i would always check as i said....don't think that anybody wants to fly with strange settings
Users browsing this forum: Bing [Bot] and 38 guests
