It is currently Sat 23. Nov 2024 19:42:47
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
 Post subject: Re: Banks
PostPosted: Wed 24. Jun 2015 12:58:03
Thanks for replying. Your English is a lot better than some of the people I know here in the USA.
I tried reading the radio manual but could not understand it.
I will try it when I get home from work.
Thanks again,
Joe
PostPosted: Thu 25. Jun 2015 0:23:29
Works great icare. Thank you for your help.
Maybe Thomas should put that in his Futaba Transmitter Setup Guide!
PostPosted: Tue 30. Jun 2015 12:44:25
Great, we will update the Futaba Guide soon.
PostPosted: Fri 27. May 2016 20:42:26
How does it work then ? i did as you said and i have sg in the middle position so bank 1 is set to stabilization mode.
logic done on idle up 3 sh...........so in the software it changes to hf mode .............ok with you so far, but hitting the idle up 3 switch doesn't activate bail out ....or what am i doing wrong .....i need a drink of cider
PostPosted: Tue 31. May 2016 14:48:11
OK o there is no bail out in stabilization mode..........................just stable or not ...............is that it ?
Coming back to this things have changed.
Users browsing this forum: Bing [Bot] and 68 guests
