It is currently Sat 23. Nov 2024 20:17:56
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue 24. May 2016 9:29:38
And we can continue to use the "old" 2.0.1 Jeti BIN file? Or there will be a new 2.0.2 version of that?
PostPosted: Tue 24. May 2016 9:31:16
Yes, the firmware was designed so the update is not needed yet.
Soon there will be update of the Jeti file that will bring just a new features, but now it is not needed to fix the problem.
PostPosted: Tue 24. May 2016 9:33:44
Thomas!
Thank you for your flawless support! :) Best support i met ever !
PostPosted: Tue 24. May 2016 9:50:12
Gtamas wrote:
Thomas!
+1
Goblin 700C Red Carbon, Cool Kosmik 200, Pyro 800-48, MKS X8 HBL 850/880 HV, Spirit-Pro, Jlog2.6GW, GPS-Logger 2
Jeti DS-16 Red Carbon+REX7
PostPosted: Tue 24. May 2016 10:06:45
Perfect. Thanks a lot!!
PostPosted: Tue 24. May 2016 11:35:59
Thanks Tomas, will try it tonight.
PostPosted: Wed 01. Jun 2016 3:16:51
ZeXx86 wrote:
Please download and flash this firmware:
http://spirit-system.com/dl/fw/spirit-fw-2.0.2-ex.4df
Finally the problem should be solved with REX receivers, we have found the problem.
Also the communication should be little bit faster now.
Response was different in a specific situations, now all should be good.
I recommend this firmware for all REX users, but it affects just the integration.
Would this firmware be ok to use without a REX receiver? I'm just about to setup my first Spirit Pro with a Jeti. Using a R3-RSW receiver for now.
PostPosted: Fri 03. Jun 2016 18:28:11
Yes, you can use this firmware. But for EX receivers it is not needed.
PostPosted: Fri 03. Jun 2016 21:02:07
Awesome, thank you.
PostPosted: Mon 06. Jun 2016 18:07:23
Hi Tomas,
after destroying and rebuilding my Goblin 700C I have tested your Firmware 2.0.2-ex with my Jeti and all seems perfect now.
Many Thanks again for your fast response and fixing.
Best Regards,
Frank
Users browsing this forum: Bing [Bot] and 48 guests
