It is currently Sat 23. Nov 2024 16:56:03
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sun 08. May 2016 17:08:35
Nexus is known for its stock Android
PostPosted: Fri 20. May 2016 6:25:59
New update on the play store has fixed my problem with my galaxy tab s2. THANK YOU!
Sent from my SM-T710 using Tapatalk
PostPosted: Fri 20. May 2016 11:18:29
It is good news, I am glad that everything is fine.
Logo 600 3D -> Spirit FBL
Spirit settings Developer
PostPosted: Fri 20. May 2016 11:49:40
Same here :)
PostPosted: Sat 21. May 2016 18:59:01
Did a lot of tweaking today, the dongle works superb! I even forgot to disconnect power of the dongle for 1 flight :) nothing weird happened. Having it dissable power or the wifi signal when starting the heli will make this an perfect addon.
PostPosted: Sat 21. May 2016 19:04:02
You could use an Rx switch and assign power to Bluetooth with a switch on your TX
PostPosted: Sun 22. May 2016 2:19:38
velocity90 wrote:
Having it disable power or the wifi signal when starting the heli will make this a perfect addon.
The question is... what is "starting the heli"?
Motor? No, then you can't make vibe analysis or Governor config...
Flying? No, you have to be able to move the heli...
Possible, but not as easy as it seems...
PostPosted: Sun 22. May 2016 17:10:37
It will come :)
Users browsing this forum: No registered users and 30 guests
