It is currently Sat 23. Nov 2024 17:27:26
PostPosted: Thu 19. May 2016 20:21:31
I have just upgraded my first of the three units I own and also added the updated bin file to my Jeti DS16 transmitter.
Regarding the status of the servos on the system
I have taken out all the reversals seen in the servo channels that matter are all now viewed as 'normal' in the DS16's servo setup screen.
The set up looks to be all completed successfully.
If I now enter Device explorer on the DS16 and enter the Spirit setup I see an difference with the status of the servos, all are shown to be reversed with a YES displayed on the TX.
So CH1-4 are viewed as 'normal' in the tx servo setup screen and viewed as reversed in the intergrated Spirit setup in device explorer.
A bit confusing, any ideas here?
PostPosted: Thu 19. May 2016 20:26:20
you should see very same Reverse configuration in both PC and Jeti.
Please make sure that you have the Spirit.bin file that can be downloaded in our web page:
http://spirit-system.com/dl/jeti/Spirit.bin
Version of the BIN file has to correspond with the firmware in your unit.
Maybe the problem is just there.
PostPosted: Thu 19. May 2016 20:48:55
OK, thanks.
Just downloaded again and all is now working OK.
PostPosted: Thu 19. May 2016 20:59:31
Perfect.
In case of any doubts you can press the Refresh button anytime in the menu.
I just dont recommend to use both computer software and integration at the same time.
Users browsing this forum: No registered users and 29 guests
