It is currently Fri 22. Nov 2024 15:12:58
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: [iOS App] Bug report
PostPosted: Wed 18. May 2016 21:52:49
This thread is used for reporting the app issues.
iOS app that is currently in the testing via TestFlight.
 Post subject: Re: [iOS App] Bug report
PostPosted: Wed 18. May 2016 21:57:56
Some general layout issues on ios9 iPhone 6:
Also application crashes after clicking connect:
PostPosted: Wed 18. May 2016 22:02:24
Thank you very much for the report.
Actually the wizard shouldn't be accessible at all (at the moment).
How did you entered it? :)
PostPosted: Wed 18. May 2016 22:05:30
It's on the first screen when I open the app!
Guess you've got a config value not being reset on the build :)
PostPosted: Wed 18. May 2016 22:53:49
On the iPad it's much better layout wise. However here if I select switch to demo mode = no then all the buttons are enabled (they are disabled on the iPhone). Taping on any crashes the app.
Oh and in both iPhone and iPad there is no demonstration mode button visible!
PostPosted: Thu 19. May 2016 0:20:26
Same issue on my iPhone 6 (layout). The wizard started right away.
I also just ordered the Wifi adapter today, so should be able to properly test it once that arrives.
Cheers
Tim
PostPosted: Thu 19. May 2016 10:27:36
Thank you for the reports.
Tommorow new version will be published with fixes for some issues (described in the changelog).
PostPosted: Thu 19. May 2016 18:49:38
New version - some layout issues with iPhone 6.
Also the app does not fill the screen. Wifi module is coming tomorrow so will test the rest of the screens then!!
Horizontal scroll bar:
Button labels:
Working well in landscape
But then this screen displays scroll bars:
PostPosted: Fri 20. May 2016 11:46:40
Wifi unit arrived.
Connects OK with the mobile app.
Bugs:
1. Layouts on the screens are unusable at present on iPhone as they all show scroll bars etc and need to switch to landscape/portrait to get the content to move to the right place
2. Haven't tried it functionally in detail but the bug I've seen so far was when clicking on the governor button it crashes the app.
PostPosted: Fri 20. May 2016 11:51:38
Thank you for the report.
You can easily move with two fingers the screen if there is a scrollbar.
Vertical scrollbars are OK, but horizontal shouldn't appear. We will try to fix it today.
We are testing on iPad, everything fits there and is good so iPhone reports are helpfull.
