It is currently Mon 25. Nov 2024 12:57:02
 Post subject: Gear ratio up to 14/1
PostPosted: Tue 10. May 2016 4:32:42
So I have an oxy 3 with 140t main gear and 10t motor pinion. The software only allows me to go to 12.7 ratio but I really need 14. Is this a limitation or can we get to 14 with a software change?
Sent from my SM-G930V using Tapatalk
PostPosted: Tue 10. May 2016 8:29:09
Previously there were same questions about this issue with solution. I will try to find it.
PostPosted: Tue 10. May 2016 20:52:50
Have a look at this:
viewtopic.php?f=20&t=1162&view=next
If I understand it correct, by doubling sensing divider and halving gear ratio, you should end up with same rpm.
Motor field rpm = rpm * GearRatio * SensingDivider = rpm * GearRatio/2 * SensingDivider*2
I hope higher gear ration will be introduced in next minor release.
PostPosted: Wed 11. May 2016 3:23:53
Cool I'll try it out. Thank you.
PostPosted: Wed 11. May 2016 3:53:09
That did the trick. Thank you.
PostPosted: Wed 11. May 2016 6:45:46
your welcome, Adrian
