It is currently Sat 23. Nov 2024 20:01:22
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat 30. Apr 2016 19:05:30
Thank you, will be patient...
Lars
PostPosted: Sat 30. Apr 2016 22:04:22
Please also look here for a bug. Unfortunately the poster (flying buddy) didn't get any response and for that reason stopped using the Spirit :
viewtopic.php?t=1352
PostPosted: Sat 30. Apr 2016 22:27:42
That is sad. If you are working 16h each day, you can unfortuntely overlook some question.
I wish him all the best!
PostPosted: Sun 01. May 2016 14:03:28
Hi!
I've come to confirm it.
After boot, i can switch banks. But when i go into device explorer and spirit ( its enoght to just open it, and do not change anything ) and when i close the menu, i no longer can change banks from the TX.
Spirit Pro 2.0.1, jeti DS16 4.0, 2.0.1 bin file loaded on tx.
PostPosted: Sun 08. May 2016 7:54:13
Hi Thomas,
any News about our Problem?
Regards,
Lars
Lars
PostPosted: Sun 08. May 2016 17:24:56
yes. We are still unable to find any issue with bank switching.
It just works as it should. It is looking like our Jeti TX firmware that was provided to us is working differently than the official one thus we have to contact Jeti in this matter. I believe we will find the problem in the following 2 days as it is really strange.
If possible, could you try the following procedure, please?
1. Enter the Spirit device in the Device explorer with previously selected Bank 0 (by switch)
2. Go to the Bank Switching, what value do you see in the Current Bank? (it should be 0).
3. Enter the Bank switching via TX
4. Select Bank 2 by switch
5. Click Refresh button and then enter the Spirit device again.
6. Go to the Bank Switching, what value do you see in the Current Bank? (it should be 2).
PostPosted: Sun 08. May 2016 17:57:48
Hi Tomas,
1. ok
2. yes, I see Bank0
3. ok
4. ok
5. ok
6. no, it´s still bank0
here is the Video from the test:
https://youtu.be/qmP6H-yUGCA
Same test with previously selected Bank1 (by switch):
1. ok
2. yes, I see Bank1
3. ok
4. ok
5. ok
6. Yes, I see Bank2
best regards,
Frank
Goblin 700C Red Carbon, Cool Kosmik 200, Pyro 800-48, MKS X8 HBL 850/880 HV, Spirit-Pro, Jlog2.6GW, GPS-Logger 2
Jeti DS-16 Red Carbon+REX7
PostPosted: Sun 08. May 2016 18:16:38
Thank you very much!
Yes, there are clear differences.
I can find the problem at 0:20 - when you select this option, transmitter should return to the Device Explorer menu always after selecting Bank Switching via TX.
If no, then bank switching by a switch will not work.
This mean, that the problem will happen, because it will not leave the Spirit integration menu. Now we have to only find why it does not leave the menu, when it should and fix it.
PostPosted: Sun 08. May 2016 19:04:30
Thanks in Advance!
Good Job!
Lars
PostPosted: Sun 08. May 2016 19:08:31
Hi Tomas,
sometime after I switch through the banks, it´s working, but I don´t know why.
They are 2 problems.
1. no return to the Device Explorer menu after selecting Bank Switching via TX
2. if bank switching is working after the above described problem, my bank0 with selected Stabilisation-Fuction is not correct, because Rescue is also activated at the same time. Normally my Rescue via momentary Button is not active if I´m in bank0
At the end from the Video you can see the working bank switching again, after I switch a few times through the banks via menu.
You can see this in the next videos (my old videos also):
https://youtu.be/ZTLpDaw6rHg
Users browsing this forum: Bing [Bot] and 50 guests
