It is currently Sun 24. Nov 2024 1:31:08
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat 30. Apr 2016 14:44:15
That's automatic, I can't see that
PostPosted: Sat 30. Apr 2016 14:45:07
Yes 7 march, I used it before that I think last.
PostPosted: Sat 30. Apr 2016 14:47:02
Sorry used it beginning of april last and it worked fine.
PostPosted: Sat 30. Apr 2016 17:05:50
Any ideas or is it broken?
PostPosted: Sat 30. Apr 2016 17:12:09
If modules were connected in a wrong way, then some damage might unfortunately happen.
If no, then there is only rather software issue - for example pairing. But nobody else reported an issue.
Do you have any other device (phone/tablet) for testing?
PostPosted: Sat 30. Apr 2016 17:15:02
Yes, its the same on my tablet. It was never wrongly connected
PostPosted: Sat 30. Apr 2016 17:17:21
When is the new thing coming and is it for Android? Else ill order a new dongle I guess but worried about the quality if they die this quickly
PostPosted: Sat 30. Apr 2016 17:38:57
If it was connected properly we will of course fix the modules for free under warranty.
Personally I can't imagine situation when two different things die without a reason. So either there is no real issue (only software as I said before) or there was something wrong (we can tell this after examination).
From your description it looks like they are operating correctly - if LED is On when pressing the Connect button, they are fine.
You can also examine modules easily by multimeter - measuring resistance between two wires in the data cable. There must be no short, but resistance higher than 40kOhms.
Power supply cable will be most probably OK, as the modules are powered well.
Can you please take a photo of the connection in the SYS port, please. Then we can be perfectly sure that it is connected fine.
Yes, new module will be also for Android. But it is better to find reason for your current issue (solution can be faster and cheaper/for free).
PostPosted: Sat 30. Apr 2016 17:45:49
Will make the pictures tonight but its perfectly connected, will also measure ohms.
PostPosted: Sat 30. Apr 2016 21:01:02
Heres the picture, you can't do this wrong. My multimeter is not here at the moment so I can not measure it unfortunately.
Users browsing this forum: No registered users and 48 guests
