It is currently Sun 24. Nov 2024 1:32:51
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sat 30. Apr 2016 12:16:08
I tried to use the bt module on my second spirit. Bluetooth finds the Spirit but if I connect with the software it says it can't find spirit data. Are the dongles protected to only work with one unit? Strange thing is it stopped working on my first unit as well.
PostPosted: Sat 30. Apr 2016 12:29:56
And a quick question, is the sys port ground shared, thus can it be used for ground of a rpm sensor?
PostPosted: Sat 30. Apr 2016 12:42:41
PostPosted: Sat 30. Apr 2016 13:34:42
Did you check if the plug in then SYS port is plugged in correctly, or is it reversed? Happened to me.
PostPosted: Sat 30. Apr 2016 13:39:05
It's correct, tried numberous times :(
PostPosted: Sat 30. Apr 2016 13:40:11
I guess that you are powering the module from a different power source than the unit.
This can be reason for described behavior. You have to also connect grounds between these sources.
PostPosted: Sat 30. Apr 2016 14:11:15
Connected to sys and power from ch0, all my helis are powered by 1 bec
PostPosted: Sat 30. Apr 2016 14:18:20
Thanks for the info.
Are you sure that the SYS cable is oriented correctly?
Do you remember if there was some update before the issue occured for the first time?
PostPosted: Sat 30. Apr 2016 14:28:35
Of the software you mean?
PostPosted: Sat 30. Apr 2016 14:42:45
Yes - android app.
Users browsing this forum: No registered users and 52 guests
