I did not play with the sensor filtering.
At the beginning, I was connected to Spirit via phone and saw, that it reads RPMs well.
Once, I started engine with connected BT unit and achieved about 16k RPM (on the ground) and saw, that Spirit reads RPM well.
I do not use Spektrum RPM senson, but Align RPM sensor (from Align RCE-G600). I read that Align RPM senson should work with Spirit.
The Align sensor is powered from Spektrum telemetry (about 3,3V).
Align sensor works well with spectrum telemetry and is able to work with Futaba GV-1 (even though that GV-1 is showing “detecting magnet” when the magnet is not under sensor and showing “magnet is not present” when the magnet is under sensor /it is reversed/, but it works).
Frankly speaking, I saw that some settings in Spirit has some effect on rotor speed. E.G. When I was increasing Holding performance, there was bigger and bigger overspeed when I went from a maneuver to hover. When I was decreasing gov response, I saw that RPM went down during tictics, when I was increasing gov response, it holds better during maneuevers. Based on it and logs from Spirit, I decided that governor was enabled and “worked”.
I made some PRT SCS after one of the test from fly – see attached. There is mentioned that governor was activated and no other information about noise from sensor etc.…
Frankly speaking, I was in touch with a guy from Helifreak and he told me, that Spirit Gov did not work either in his GAUI NX4 (unfortunately, I got this information when I already switched to Spirit GOV – but I tried to test and share the results at least).
As I mentioned before, I would say, that it might work something like:
Gov response: 7 or 8
Holding performance: about “-2”
- or somehow teach the Spirit Gov, when is idle, when stop and when max. Maybe set there, that it is glow/gas and not electric and use different algorithm.
Based on the results, logs, videos, feedback from different users and workable Futaba GOV (and Align gov worked as well - but it overspeed it little as well - therefore I decided to change it) I still have to claim that the Spirit Gov does not work for OS 37 and GAUI NX4... It is able to hold RPM during maneuvers, but it overspeed rotor when you exit from maneuver.
Depends, if you want/are you interested to deal with it for, lets say, smaller group of users...
