It is currently Sun 24. Nov 2024 5:36:23
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Devo 7
PostPosted: Mon 04. Apr 2016 23:49:35
Tail servo is 620 should i use 333h?
PostPosted: Tue 05. Apr 2016 10:14:55
Yes, 333Hz is good for this servo.
Rudder Delay should be at 10 to achieve better results.
PostPosted: Sun 10. Apr 2016 16:19:44
You were correct by setting the rudder latency to 10 jn the servo to 300hz made the diference.
I got a very very small tail move and imidiate recovery on very hard pitch ups and down
Thanks guys, great support and unit
PostPosted: Mon 11. Apr 2016 9:30:30
Perfect,
you are welcome!
PostPosted: Sun 17. Apr 2016 16:32:20
ZeXx86 wrote:
Perfect,
you are welcome!
Yeap tweaked settings a little more and tail is solid rock no matter what. Only issue now is that when i hit rescue the heli is not going straight up. I checked the swash is level and the heli is initializing on flat surface
Anything else to try?
PostPosted: Sun 17. Apr 2016 16:40:31
How many degrees of error?
PostPosted: Mon 18. Apr 2016 7:35:01
Can you tell me which firmware version do you have and if you are moving with the helicopter after initialization? (before flight).
PostPosted: Sun 24. Apr 2016 17:36:24
hello
i have the latest firmware
i have tryed both 1)power up and flight imidietly after init without moving the heli and 2) power up , let it init on the table and move it to flight sight 10 feet away for flight
PostPosted: Sun 24. Apr 2016 20:25:15
PostPosted: Tue 26. Apr 2016 8:38:58
i would say about 10 to 15
Users browsing this forum: Google [Bot] and 15 guests
