Zed wrote:
Just a little elaboration
My flight mode 0
Throttle curve is linear 0-25-50-75-100
Pitch curve the same
My flight mode 1
Throttle curve Is 75% across
Pitch curve linear
My flight mode 2
Throttle curve is 90% across
Pitch curve linear
My goal is to have FM 0 and 1 stability and bailout
FM 2 is to have bailout.
This is where things get complicated for me:
Go to Function List → Gyro
Configure Sw to F Mode. Then set the Gyro Gain for each Flight mode.
By changing Gyro Gains we can perform bank switching in this method.
So it can look like:
• Normal: -100% • Stunt 1: -100% • Stunt 2: 0%
• Hold: 100%
(Bank 0) (Bank 0) (Bank 1) (Bank 2)
Then in the Sensor tab, you can configure Rudder Gain for each bank separately.
So it can look like: • Bank 0: 60% • Bank 1: 60% • Bank 2: -60%
You are almost there!
I would only change the Gyro value for Hold in your DX8 to 0, so that when you are in Hold, it's in Bank 1 so stabilization is not active and you can better perform your pre-flight checks.
Another thing: in the Spirit, Rudder Gain for Bank 0 should be negative (so -60%) for Stabilization mode to be always active.
What you miss now is just the setup of the DX8 to activate Rescue.
The idea is to have a button or a switch that sends you to Bank 2, by outputting something around 100 or more to the Gyro channel.
In the DX8, the best way is to have a mix adding 200 to the Gyro channel (a mix like 0 100 100), I can be more specific if you need.
