It is currently Sun 24. Nov 2024 19:42:32
[ 5 posts ] |
bill rob
Posted: Fri 01. Apr 2016 17:04:19 |
Ive decided to change from PWM set up to just the spirit with satellite.Do I just need the first mix?,,,,I only want rescue. Also in the diag tab my ele only goes to 50% both directions?,,if I increase travel adjust up to 150 I can get it to 75% each direction,any idea how I can get it to 100%? Do I have to use a governor with satellite set up?
Thanks in advance
Adrian
Posted: Fri 01. Apr 2016 19:21:14 |
Joined: Thu 08. Oct 2015 14:43:12 Posts: 204 Location: Switzerland
I have got DX9 and sat. Almost no adjustments on servo travel, required all arround 125 +/-2 points I suggest setting up new model in transmitter and start over with spirit setup wizzard. Might also try to save and reboot spirit after RX change, I do also suggest to use two sats if possible.
_________________ Oxy4max SpiritPro + HW // SOXOS 550, SpiritPro, HW120A V4, 920KV // SOXOS 600, SpiritPro, HW160A, Pyro650 // SOXOS Strike7, SpiritPro, HW160A, Pyro750 // Skywing Spirit Aero // FrSky Horus X10S + Taranis X7 /
bill rob
Posted: Fri 01. Apr 2016 20:08:32 |
Posted: Sun 03. Apr 2016 10:25:03 |
Yes, I guess that you have some old settings in your transmitter - with new profile it should be better to start.
bill rob
Posted: Mon 04. Apr 2016 16:35:08 |
I did have old settings so made new model and all good. Thanks
[ 5 posts ] |
Users browsing this forum: mainstreet and 68 guests |
