It is currently Mon 25. Nov 2024 0:53:07
PostPosted: Thu 24. Mar 2016 18:47:44
Hello everyone I have setup my Oxy 3 Qube main and tail with the spirit fbl and I have a little tail kick and the p gain and revo-mix is at the limit
Pgain at the max before tail hunting
So what can I do now or what is the problem to much pitch maybe for a 3 blade?
Best regards Joeri
Verstuurd vanaf mijn SM-N910F met Tapatalk
PostPosted: Thu 24. Mar 2016 18:48:46
Increase your piro consistency. You shouldn't need any revo mix. I was having the same issue and just upped the piro consistency parameter and was all gone on my 450L
You'll probably need to drop the p gain a bit as well.
PostPosted: Thu 24. Mar 2016 19:00:23
Ok thanks I try that and lower the revo-mix again then?
PostPosted: Thu 24. Mar 2016 19:53:19
Yeap you shouldn't need any revo mix
PostPosted: Fri 25. Mar 2016 18:29:31
Thanks for the tip man that's works great! I only have tail wag now... And before not :/
Best regards Joeri
PostPosted: Fri 25. Mar 2016 18:33:10
Best regards Joeri
Drop your tail gain. Also what is your rudder delay value? What pirouette consistency did you end up with?
PostPosted: Mon 04. Apr 2016 23:42:05
I go to the field tomorrow hopefully and test it with lower tail gain.. And let you now the value of the consistency
PostPosted: Tue 05. Apr 2016 8:02:03
Thanks! Ive noticed that now that I've setup my governor to hold rpm more aggressively I have a minor kick when doing pitch pumps. Running 175 piro consistency on my 450L. Possibly need to up even more on my side or add 1 or 2 points of revo mix. Will be trying it at the field next time as well
PostPosted: Tue 05. Apr 2016 8:43:52
You will always get a small kick with agressive govs. Tune it out with revo too much and other things become worse. Side tick tocs to name one.
Users browsing this forum: No registered users and 76 guests
