It is currently Sat 23. Nov 2024 15:36:16
PostPosted: Wed 23. Mar 2016 21:18:28
any settings to start with for the t-rex 550 with ds610 -620 servos?
cyclic and tail gain etc ?
thank you in advance
PostPosted: Thu 24. Mar 2016 13:35:12
Hi,if you follow the wizard you should discover the settings for your heli,I had to go through the set up a good few times to get it into my head.
PostPosted: Thu 24. Mar 2016 13:53:34
Use the model preset on the wizard, as Bill is suggesting ;)
PostPosted: Sat 26. Mar 2016 13:12:45
I actually just setup this heli for a friend a week or so ago w a red spirit. So far ive found that rudder delay of 5, head gain of 60, piro consistancy at 160 and tail gain (common gain at 1.0) at 75 was a good starting point. This is where im at right now but isnt the final settings as I havent been able to tune it much more. But those settings should get you at good starting point.
Or do what everyone else says and just use the set Template in the model menu.
Users browsing this forum: No registered users and 21 guests
