It is currently Sun 24. Nov 2024 3:48:53
datamedic
Posted: Mon 21. Mar 2016 21:44:41 |
Hello
is spirit gonna work fine with my devo 7 transmiter?
thank you in dvance
datamedic
Posted: Mon 21. Mar 2016 22:59:32 |
Coco66
Posted: Mon 21. Mar 2016 23:15:59 |
It's not about the TX... it's only about what protocol the corresponding receiver supports... what did you have in mind?
Posted: Tue 22. Mar 2016 9:47:42 |
What receiver do you have for this transmitter?
datamedic
Posted: Tue 22. Mar 2016 17:20:10 |
my receiver is devo 1201
curently working great combined with beastx on all 4 on my helicopters
here all the specs i found Specifications Type: 2.4GHz 12 channels Sensitivity: -105dbm Frequency Interval: >/=4M Weight: 15g Dimension: 47 x 32 x 16mm Receiver Battery: 4.8V1100mAh
Features Adopts 2.4GHz Direct Sequence Spread Spectrum (DSSS) that features fast reaction and strong anti-jamming protection.
Double reveiving circuits effectively assure the stability of receiving singal.
The Single Chip Micyoco as CPU provides super-strong analysing ability.
The output of singals simultaneous increases the ability of synchronization.
11 Millisecond and 22 Millisecond Frame Rate selectable.
The RECEIVER maintains the frequency and the ID memories when its changing a new battery pack with the transmitter powered on.
It can be customizedly set as fixed ID and automatic ID assignment.
Posted: Tue 22. Mar 2016 17:27:18 |
It will work with Spirit as well. Connection is very similar as with BeastX.
datamedic
Posted: Tue 22. Mar 2016 18:06:49 |
thank you i will place an order tonight , you suggest simple or pro version?
Posted: Wed 23. Mar 2016 8:17:18 |
Great!
It depends on what helicopter you have. For smaller helicopters smaller Spirit unit will fit better. For bigger ones Spirit Pro is better solution.
W.W.
Posted: Wed 23. Mar 2016 8:19:38 |
Joined: Mon 01. Feb 2016 13:37:12 Posts: 65 Location: Germany
This depends on your helicopter, since the Spirit pro is a bit larger than the "simple" Spirit. But if the size isn't an issue, I would go for the pro.
_________________ regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
datamedic
Posted: Wed 23. Mar 2016 9:28:05 |
thank you for your fast replies , i have ordered the simple since the pro was at backorder im intenting to use it on my t-rex 550 for testing
i will order the pro for my 600 and my velocity once i got used the setup and tuning
ill post back soon, since im using devention tx and rx and there are no info on them , it might help someone else in the future
Users browsing this forum: No registered users and 53 guests |
