It is currently Sat 23. Nov 2024 15:21:16
PostPosted: Sun 20. Mar 2016 15:35:49
on version 1.3.0, both dsmx satellites were working OK.
After the update to v 2.0.0, only the dsmx connected to DSM2/X Satellite port is working and the one connected to the rudder port via satellite adapter isn't.
There is no blinking light or anything. If I disconnect the satellite and reconnect it, I only get a short led blink.
Where could be the problem?
PostPosted: Sun 20. Mar 2016 19:12:00
I guess that the problem was not caused by update, but your satellite lost bind data.
It should be enough to rebind it with a bind plug.
Satellite does not need unit at all to be On, only power supply is needed.
PostPosted: Mon 21. Mar 2016 8:24:28
Well, than probably the Spektrum adapter cable died all of a sudden.
Have to check that.
Thanks!
PostPosted: Mon 21. Mar 2016 8:30:03
If you can see a short blink of the LED there, then it is most probably OK.
You have to only rebind the satellite.
Maybe there is just wrong or losee connection.
PostPosted: Mon 21. Mar 2016 9:01:03
I did rebind, but only the satellite connected to satellite port, rebinded and the one connected with the adapter did not (there was no light at all).
I should also mention, that te one connected to the satellite port is original Spektrum satellite and the one connected to rud port is Lemon RX dsmx satellite.
PostPosted: Mon 21. Mar 2016 9:09:34
Oh, generally it is not too recommended to use a different satellites. But it should work.
Can you try to swap the satellites? If the Spektrum will work with Spektrum adapter then there is a different problem.
PostPosted: Mon 21. Mar 2016 9:14:27
I will try to swap the satellites.
But it worked for year and a half now.
PostPosted: Tue 22. Mar 2016 19:21:18
Here is what I've found out.
After the upgrade to v2.0.0, I also changed my radio (from DX6 V2 to DX9 Black).
Today I powered on my DX6 and voila, both satellites worked, than changed back to DX9 and only the Spektrum satellite works.
I don't know where the problem is, guess Spektrum changed something in the newer DX9 Black edition radio.
Oh and btw, the Lemon RX satellite is DSMX, because the DX9 Black doesn't support DSM2 anymore so I guess that's not the problem.
PostPosted: Tue 22. Mar 2016 19:32:50
Wow. You all can see how much the information that we decide is relevant or not to include in the description of our problems can make the difference!!
PostPosted: Wed 23. Mar 2016 10:00:37
Yes, that's right :mrgreen:
Users browsing this forum: Bing [Bot] and 23 guests
