It is currently Sat 23. Nov 2024 14:08:59
 Post subject: No throttle movement
PostPosted: Wed 16. Mar 2016 12:54:23
Hi,I can get everything at -100 +100 on servo screen but no pitch/throttle movement,,any ideas?
thanks
 Post subject: Re: No throttle movement
PostPosted: Wed 16. Mar 2016 13:03:47
What transmitter /receiver, have you assigned thr to ch1? (off by default) its in the channel maping next to your receiver type.
PostPosted: Wed 16. Mar 2016 13:11:32
you have probably leaved your default Gyro Gain settings in your transmitter and it is set to 0%.
Probably you have also configured Function as Rescue, so your rescue is activated all the time.
You have to set positive gyro gain and then it will be fine.
PostPosted: Fri 18. Mar 2016 13:28:05
Ok I have followed the guide for DX9 set up an the forum here,so I will try again through set up tonight after work,thanks for the advice guys.
PostPosted: Fri 18. Mar 2016 15:43:26
Hi,should I have power from ESC plugged into throttle on receiver or into aux on the unit?
pwm wiring.
PostPosted: Fri 18. Mar 2016 17:10:50
You are using a build in bec? Manual states to use 2 lines from the receiver to aux and rud to supply power. Esc goes in the receiver.
You could also put the power pins in an other connector and connect to rud or aux and place a connection between the other free port (aux or rud which ever you didn't use) and the receiver, Any free port.
PostPosted: Fri 18. Mar 2016 17:51:50
Perfect you cleared that up for me ,thanks,
Bill
Users browsing this forum: No registered users and 41 guests
