It is currently Sun 24. Nov 2024 10:29:11
 Post subject: Tail Setup
PostPosted: Tue 15. Mar 2016 17:35:48
Please can you clarify the correct tail pitch when the rudder servo is centred?
The manual indicates the tail pitch should be zero, however, all other FBL units I have used require 2-3 degrees against the torque.
If this is zero, will the heli rotate when the gyro is in rate mode?
 Post subject: Re: Tail Setup
PostPosted: Tue 15. Mar 2016 17:36:32
Check here: viewtopic.php?t=1279
Users browsing this forum: Amatrix and 54 guests
