It is currently Sat 23. Nov 2024 17:08:28
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon 14. Mar 2016 12:34:19
Stock nexus 9 marshmallow
PostPosted: Mon 14. Mar 2016 12:36:05
Just a thought but why not 2 buttons in the connection menu :
-save changes and disconnect
-disgard changes and disconnect
PostPosted: Fri 22. Apr 2016 4:53:41
Menu button does nothing on my galaxy tab 2 but it does work fine on my nexus 5x
Sent from my SM-T710 using Tapatalk
PostPosted: Fri 22. Apr 2016 9:03:34
Well, lets hope auto saving after changing one setting is there in the future, also in the pc software. Pretty annoying to have to manually save things. Im kinda used to raising a gain disconnect and go fly. The number of times ive forgotten to save, arggg
PostPosted: Fri 22. Apr 2016 12:47:44
Pretty sure the App warns you (and also the PC software IIRC)... so it should become very quickly something you don't forget anymore!
Or are you the kind of person who does not learn from his mistakes? )))))))))))
PostPosted: Fri 22. Apr 2016 12:49:22
No Warning in the app nor in the pc software. Its annoying and unnessesary.
PostPosted: Fri 22. Apr 2016 12:53:48
We do not plan to change this behavior. Automatic saving means significantly shortened durability of the processor memory.
These memories are limited in number of rewrite cycles. If exceeded you can throw it. If you are configuring very often than with autosaving the unit can work not more than one year.
We wish that our units can work for tens of years.
Whats more it is also good safety protection. When you are just trying a new configuration and you dont remember the old one, you can just plug the battery off and it will return back.
By the way you can press anytime CTRL+S. It is very quick.
PostPosted: Fri 22. Apr 2016 12:56:50
Ok, I need a way to save on my tablet because there's still no menu showing :(
PostPosted: Fri 22. Apr 2016 13:00:02
You can save either by Menu button or by pressing 3 dots icon to show the menu.
We are trying to find good solution for this problem.
PostPosted: Fri 22. Apr 2016 13:39:24
Both dont work on marshmallow Android
Users browsing this forum: No registered users and 37 guests
