It is currently Sat 23. Nov 2024 17:32:39
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Sun 13. Mar 2016 15:41:28
Im i suppose to save the changes I make manually? If I disconnect it says changes are not saved.
PostPosted: Sun 13. Mar 2016 16:29:45
It works in the same way as the PC software.
You should save settings to the unit if you want to store it permanently (not loose with a battery disconnection).
PostPosted: Sun 13. Mar 2016 17:02:43
Ok where can I find the save function?
PostPosted: Sun 13. Mar 2016 17:08:14
In the context menu - there are many other functions as well. Just press the Menu button or "3 lines" icon.
PostPosted: Sun 13. Mar 2016 17:59:13
That explains, menu button not working on my nexus 9 tablet :(. (Android marshmallow)
It does on my phone(kitkat)
PostPosted: Sun 13. Mar 2016 22:31:40
you can tap to "three blue dots" on top-right on screen or you can slide from left to right and then tap to "menu"
check this
Logo 600 3D -> Spirit FBL
Spirit settings Developer
PostPosted: Sun 13. Mar 2016 23:15:09
I know, doesn't work on my nexus 9 (marshmallow) does on kitkat
PostPosted: Mon 14. Mar 2016 0:01:28
Also sliding does not work?
PostPosted: Mon 14. Mar 2016 5:44:27
Sliding does work but the menu button does nothing
PostPosted: Mon 14. Mar 2016 10:10:08
hmm this is problem :( Do you use android from google or some custom ROM? It seem that I have to rewrite menu in android app.
Users browsing this forum: Bing [Bot], gerry and 31 guests
