It is currently Sat 23. Nov 2024 17:13:55
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 10  Next
PostPosted: Wed 09. Mar 2016 20:46:03
Great, was the transmitter started before the unit?
PostPosted: Wed 09. Mar 2016 21:05:05
offcourse Always
PostPosted: Wed 09. Mar 2016 21:24:10
Please check if the governor is active in each bank.
PostPosted: Wed 09. Mar 2016 21:50:07
How? Its greyed out, I have the gyro channel set to rescue and don't use banks until we get an 8th channel.
PostPosted: Thu 10. Mar 2016 8:12:39
Do you need me to check this? I'm sure it's by default settings, I dissabled it from the start. I don't see any option in the software too switch the bank manually.
Verstuurd vanaf mijn HIGHWAY SIGNS met Tapatalk
PostPosted: Thu 10. Mar 2016 9:04:13
Just to verify - are you starting unit/transmitter with throttle hold active?
Something looks to be out of range during powerup.
If you increase throttle hold position little bit in your transmitter, does it go to 1%? If so, you can return it to 0%.
PostPosted: Thu 10. Mar 2016 9:47:14
I always start my transmitter, thr hold on, then I powerup the Spirit. What do you mean 1%?
PostPosted: Thu 10. Mar 2016 10:00:04
I think that your problem is related with the transmitter configuration.
Our upcoming firmware will not allow to deactivate governor because of this.
I will contact you regarding this with PM so you can try possible solution.
PostPosted: Thu 10. Mar 2016 10:36:01
Ok but everyone surely has it like me, nothing weird here.
PostPosted: Thu 10. Mar 2016 10:42:39
Indeed, something is not correct - most probably from the beginning and this is the reason why you was afraid about fast spoolup.
You can try the easiest things first - for example just reflash the firmware.
Then you might try to open the software and verify, if you can see Requested RPM there (during the first spoolup).
If not, then the problem is really related with the throttle signal.
Users browsing this forum: Helihello and 36 guests
