It is currently Mon 25. Nov 2024 3:41:37
PostPosted: Fri 26. Feb 2016 19:30:03
I just setup my TT E700 with the new 2.0.0 on a spirit pro.
Got all ok except swash should go down in positive collective.
I could solve this by reversing de collective channel in the transmitter but rescue collective is still in wrong ditection.
Is there a way to tell the fw that swash is reversed ?
PostPosted: Fri 26. Feb 2016 19:53:38
You should not change collective in TX. As I guess Diagnostics is now wrong.
You should reverse Servos Ch1, 2 and 3 in Spirit following the Wizzard steps, till pitch is correct.
Than things should all work.
Or you might run in the issue like trailing blades.
viewtopic.php?p=13651#p13651
PostPosted: Fri 26. Feb 2016 19:59:05
Well I tried that but in this case, directions are reversed.
Just looking in other posts it seems thisis the same issue as for Coco66 with his 450X
viewtopic.php?t=1203
PostPosted: Fri 26. Feb 2016 20:06:24
Got the same in mind.....
PostPosted: Fri 26. Feb 2016 20:40:44
I think Tomáš will contact you since he can send you a firmware which is specific for trailing edge control.
They are currently implementing a specific setting in the official firmware/software, but meanwhile I got the "unofficial" one and it works perfectly (flown it already).
PostPosted: Fri 26. Feb 2016 22:11:01
Thanks Coco ! Will try that when I get it.
PostPosted: Mon 29. Feb 2016 13:59:23
I didn't receive any update but I could fly just like that : reversing the pitch channel and switching from rescue to stabilisation.
The E700 maiden went very well.
Just one thing : in fast circles in good wind the pitch was a bit too sensitive. The heli was going up and down without real will to do that on the sticks. But this is my first 700 probably nothing important.
PostPosted: Mon 29. Feb 2016 14:35:10
I have not received any message from you yet. But I will send you a link for the firmware.I highly not recommend to reverse pitch. It must be configured properly else other functions will not work.
PostPosted: Mon 29. Feb 2016 15:51:37
Hi Tomas, sorry I didn't request the fw directly to you.
Thanks for the link in pm anyway.
Will use it obviously on my next flight !
PostPosted: Mon 29. Feb 2016 18:03:38
Any idea of when an official fw supporting trailing edge/reverse swash operation, will be released? I have 2 Raptors and a 360 CFX rescuing downwards. :?
Users browsing this forum: Bing [Bot] and 40 guests
