It is currently Sun 24. Nov 2024 6:38:17
 Post subject: Bailout Question
PostPosted: Fri 26. Feb 2016 4:25:33
Hey guys, any idea would help with this new problem. I have an oxy3 Qube (3 head blade) and after upgrading to the latest firmware (I did everything as instructed- no problems - great setup by the way) when I activate the bailout, it always ends up with the nose pointing up a few degrees. Just enough to make the heli backup start in backward flight. Any ideas???
 Post subject: Re: Bailout Question
PostPosted: Fri 26. Feb 2016 5:18:32
Is your swash level at 0, high and low collective position? Thats where I would start. Make sure you have 0 pitch when subtrim is checked, swash is level then make sure its level at its high and low using the servo corrections.
PostPosted: Fri 26. Feb 2016 17:34:55
Following the recommended trim, check if you got a nice hoover without stabilization, than your setup should be fine.
2nd make sure your swash is level and in a perfect horizontal position during power up and stays till FBL is initialized. On some Heli you have to tilt Heli a bit forward or backward by lowering or lifting and holding tail during initialization to get perfect horizontal SP position.
PostPosted: Fri 26. Feb 2016 17:44:29
Tomas, does this make sense? Btw, I don't use stabilization. I use the rescue feature.
PostPosted: Fri 26. Feb 2016 17:59:33
I guess that the problem is somewhere in the servo settings. I recommend to check if the swashplate is perfectly horizontal in min., max. and center positions of the collective when you enter Servo Travel Correction menu.
Users browsing this forum: No registered users and 31 guests
