It is currently Sun 24. Nov 2024 2:26:32
 Post subject: wow 2.0
PostPosted: Tue 23. Feb 2016 20:23:52
This one might be set out to soon. I upgraded 2 electric and all went well. Had to move 1&3 on one but that was all.
Then I went to my nitro and all went bad. Spent 2 hrs after update and eventully had to go back to 1.3. All controls were wrong, and I mean bad, tried swapping 1&3 no good. trex 600 dfc N.
 Post subject: Re: wow 2.0
PostPosted: Tue 23. Feb 2016 20:28:05
Did you reset the reverses in the TX?
What do you mean with "all controls were wrong"? Diagnostic screen? Or not responding correctly to inputs?
I suggest to redo the setup from a clean situation, no reverses, correct CH2 and CH3, and go from there.
PostPosted: Tue 23. Feb 2016 20:41:27
all inputs on diagnose sere right from trans. Justall on heli were wrong. throttle made rudder move, ect
PostPosted: Tue 23. Feb 2016 20:44:48
Did you try saving the config, and rebooting the unit?
PostPosted: Tue 23. Feb 2016 21:11:17
yes.
PostPosted: Tue 23. Feb 2016 21:59:03
Channels assignments got lost, this could be the only explanation....
PostPosted: Wed 24. Feb 2016 0:50:33
need more help from spirit. thks
PostPosted: Wed 24. Feb 2016 9:33:20
I'd strongly recommend that you redo the setup. Reset the unit to defaults upgrade and start over with the wizard. Also reset all channel reversals on the transmitter.
PostPosted: Wed 24. Feb 2016 9:35:31
I see we are on the same page.
Unfortunately, if I read correctly his last post, the OP wants to hear from the Spirit guys only.
PostPosted: Wed 24. Feb 2016 9:36:58
+1. It just seems like an incorrect channel assignment that can be resolved in under 2 mins but to be on the safe side a clean start would be probably the best
