It is currently Sat 23. Nov 2024 12:00:24
 Post subject: Cyclic Phase
PostPosted: Fri 19. Feb 2016 23:57:40
What should this setting be for help with a 3 headed blade? 60?
 Post subject: Re: Cyclic Phase
PostPosted: Sat 20. Feb 2016 0:05:55
For many multirotor heads cyclic phase is 0°, because phasing is done mechanically.
So you have to check what your rotor head require to operate correctly.
Manufacturer of the rotor head should tell you all the details.
PostPosted: Sat 20. Feb 2016 14:57:54
Have a look on my explanation to find right phase:
viewtopic.php?p=13481#p13481
PostPosted: Sun 21. Feb 2016 0:19:52
What would the cyclic phase setting need to be on a goblin 380 three bladed heli or a oxy3 Qube?
PostPosted: Mon 22. Feb 2016 19:57:32
AFAIK, both manufacturers specify that to go from their two blades head to their three blades head the only needed change is to reduce the cyclic gain.
PostPosted: Mon 22. Feb 2016 22:04:54
it seems ambiguous with the spirit flybarless
PostPosted: Mon 22. Feb 2016 22:11:24
Where did you see any ambiguos note?
The FBL has nothing to do differently than with a two blades head, if everything has been done mechanically... why should Spirit be different?
PostPosted: Mon 22. Feb 2016 22:23:57
it ambiguous because tomas has mentioned that in some cases it doesn't need to be lowered with three blades...
PostPosted: Mon 22. Feb 2016 22:37:24
Spirit has adaptive regulation that is able to tune itself to a certain degree. So this is reason, why it can fly well with the same cyclic gain.
But generally you have to lower the gain. So everything is true.
Users browsing this forum: Bing [Bot] and 35 guests
