It is currently Sat 23. Nov 2024 20:40:41
PostPosted: Sun 21. Feb 2016 0:01:44
I have a Trex-600, OS motor, Align HE50H22 pickup and Savox 0220 throttle servo.
It works a 1/4 of the time, it is requesting the correct RPM, just goes way above it, like it's not governed at all, kind of runaway. If you switch banks it will start working some times and then after switching banks again it goes off into 200, 300 higher than requested. I'm pretty sure we have tried ever setting possible.
Would like to hear from someone that has got it to work.
Thanks for your help.
Larry
PostPosted: Mon 22. Feb 2016 21:43:41
Nope, afraid not.
Using a MultigovPro instead straight out of the box without a single adjustment.
Maybe the new update will improve things.
PostPosted: Mon 22. Feb 2016 22:40:13
Of course it should work. We are testing governor from the beginning on the electric, nitro and gasser helicopters.
With the latest firmware results are even better and I am very satisfied personally.
Together we can set it if you will need any help.
PostPosted: Thu 25. Feb 2016 11:17:13
I'd love to hear at least one person say they're using it and it's working well on their nitro..
Anyone? Anyone?
heh.
Can't wait to try 2.0 and see if it's better :D
PostPosted: Thu 25. Feb 2016 17:34:52
I will be trying the governor on 2.0 this Sat, Ill let you know how it works.
Larry
PostPosted: Mon 29. Feb 2016 18:46:29
Got to try out 2.0 on a Spirit Pro with my N5c today. This exact Heli and sensor (Spektrum backplate) wouldn't work at all on the older governor with 1.2 firmware.
Happy to report that it works fine now on 2.0. RPM is varying a couple hundred RPM as an load and unload it (seen via Jeti telemetry) but the engine was very rich and I didn't touch the stock settings for anything in the Spirit 2.0 software. Hoping to get out later in the week and do some tuning, but even as it sits it flies very well and the power delivery and consistency of the governor is close enough that a sport flier would be fine with it.
PostPosted: Tue 01. Mar 2016 11:19:19
Thank you very much for the great news.
If we can help you in any way, feel free to ask.
PostPosted: Thu 03. Mar 2016 10:15:02
Well I set my trex 700 nitro with the new v2.0 settings and it flys great with the
Standard governor settings
A bit slow to spool up but I can confirm it works 100% now
I will need to get to know what all the gov settings parameters mean now ,though
I don't like altering settings if ime unsure what they do
Users browsing this forum: mainstreet and 41 guests
