It is currently Sat 23. Nov 2024 1:53:45
 Post subject: Spirit Pro
PostPosted: Sat 30. Jan 2016 20:30:18
:o Just got a pro last week Jan 26/2016
Is it still 1.3 as spirit or new firmware. Saved file from spirit and losded into Pro for same heli. It said double click on values different software or something. It did load fine. All works well have not flown yet. Tks John
 Post subject: Re: Spirit Pro
PostPosted: Sun 31. Jan 2016 17:19:13
1.3.2 is the latest FW:
http://www.spirit-system.com/#2
after FW upgrade its always good practice to check Servo centers pitch range as well as Stick input directions.
Also check correct stabilization by rotating Heli in all directions (XYZ) Aileron, Elevation and Ruder.
If you use Spirit Governor, also check it's function without blades.
So fare, I never had any issues with new FW.
PostPosted: Sun 31. Jan 2016 17:26:53
I guess that the settings file that you have saved was created with version older than 1.3.2, this is reason why the window appeared.
The window was just telling you what you should do and why it happened. Normally it is not problem, you should only verify if everything is OK because of backward compatibility between profiles.
