It is currently Fri 22. Nov 2024 9:06:29
PostPosted: Thu 28. Jan 2016 16:44:43
Cannot view log files.
Windows 10, Adobe Acrobat Reader DC, *.pdf files set to default to AcroRead DC, but log file tries to open and says no .pdf reader found.
Any suggestions? thanks, Dan
Synergy 516, 556 stretch, 696.
PostPosted: Thu 28. Jan 2016 19:05:37
Do you still have the "My Documents" folder?
If you accidentally deleted it, it will not work.
PostPosted: Fri 29. Jan 2016 16:02:06
I still have the MY DOCUMENTS folder. It's not on the "C" drive, though. Does that matter? Does the Spirit write the log somewhere in the laptop?
thanks, Dan
PostPosted: Fri 29. Jan 2016 17:27:57
Yes, it must be on the C drive,
PostPosted: Sat 30. Jan 2016 19:26:44
Maybe better to have a dialog window with save location
DX9 - Chase 360 - Spirit
PostPosted: Sat 13. Feb 2016 19:01:36
Added a new "My Documents" folder under the "username/Documents" library, but Spirit doesn't find it. Can someone give me the correct path for the My Documents folder so I can put it in the right place? thanks, Dan
PostPosted: Sat 13. Feb 2016 21:41:26
On Windows 7 the needed folder is
C:\Users\yourusername\Documents
PostPosted: Sat 13. Feb 2016 21:45:32
Would be better to implement different mechanism how to save pdf logs
PostPosted: Sun 14. Feb 2016 13:04:57
same on WIN10:
C:\Users\[user]\Documents
+1 for save / open dialog
PostPosted: Thu 18. Feb 2016 14:28:08
Here's where I created the My Documents folder, but I still cannot save logs:
C:\Users\Daniel\Documents\My Documents
Will have to wait for a dialog box, I guess. My system C drive is a smaller solid state drive, so documents have to go to a large spinning hard drive D:
Dan
Users browsing this forum: No registered users and 13 guests
