It is currently Sat 23. Nov 2024 10:23:47
[ 2 posts ] |
GaryCam
Posted: Sat 23. Jan 2016 5:47:41 |
Just purchased a spectra G Gasser with a spirit red cased fbl system in it , not used one before , Futaba GV1 with stator gator , just wondering what plugs into R6008HS Fasst Receiver .. ? Using 12Z fasst TX ....it does have 3 axis gyro programing in TX..
Cheers
Gary...
Posted: Sat 23. Jan 2016 13:09:23 |
You will need to use PWM connection type. How to connect it is described also in the manual.
To find what number is which channel, you can find the channel assignment in your transmitter. There are corresponding numbers to the receiver ports and assigned function to it.
I recommend to start with the RUD and AUX connection, then you can connect ELE/PIT/AIL. Also make sure that the receiver type is configured to PWM in the unit.
[ 2 posts ] |
Users browsing this forum: Bing [Bot] and 21 guests |
